I feel that I understand sequential logic in Verilog using always blocks triggered on clock edges, and combinatorial logic using assignments to wires is straightforward.
What keeps confusing me is combinatorial always blocks like
reg a;
reg b;
reg c;
always @(*) begin
a = b & c;
end
Isn't this just the same as making a
into a wire and assigning to it?
I understand that combinatorial always blocks can conditionally set an output (if (en) a = b; else a = c;
) but that could be implemented as assign a = en ? b : c
I also get that the combinatorial always block need not set an output, in which case the output will remain unchanged, which requires it to be latched. There are a lot of resources out there suggesting that this is a Bad Thing and are more often than not the result of logic errors.
My question is, is there any logic that requires a combinatorial always block, or is it always possible to use a combination of sequential always blocks and wires instead? And should I feel bad about using latches or are they the best solution to certain problems?
always@*
andassign
which I guess is no longer relevant after SV introduced 'logic'. \$\endgroup\$
