Application: A machine that seals boxes with plastic wrapping. The box is sealed by applying a heating element to the plastic for a few seconds.
I have a 800VA (220VAC to 54VAC) transformer connected directly to a heating element.
My requirement is to make the transformer work with the heating element so that I can adjust the temperature, and also not break the transformer.
Initially I wanted to switch the input voltage by controlling a zero-cross solid state relay (Celduc SO842074) with a PWM signal (Arduino) on the primary side. I then learned that this may cause a DC-component or voltage spikes which could break the transformer.
My current idea is to place the zero-cross solid state relay on the secondary side of the transformer (untested). I'm uncertain as to why switching the primary side would cause a DC component but doing the same on the secondary side would not?
Will this secondary switching be safe for the transformer or will there still be a DC component / voltage spikes?
What exactly happens to a transformer when switching rapidly on the primary side compared to the secondary side?
Bonus question: What would have been a better solution?
Thank you for the help in advance
