I am figuring out the current for the following circuit:
Circuit
Using V = IR, I would expect to do I = V / R and then do:
I = (20 + 50) / (1 + 2) = 70 / 3 Amps.
However, the actual current is:
(20 - 50) / 3 = -10 Amps
Why are the voltages subtracted rather than added?
References to blog posts / textbook chapters would also be appreciated (if available).
Here's the full solution, if it helps anyone:
  • 6
    \$\begingroup\$ Are the voltages series aiding or series opposing? \$\endgroup\$
    Commented Sep 16, 2021 at 17:00
  • \$\begingroup\$ @Andyaka, I'm not sure. I guess it isn't specified? I'm using Schaum's Outline of Electric Circuits, so maybe there's some convention in that textbook. \$\endgroup\$
    – Foobar
    Commented Sep 16, 2021 at 17:09
  • \$\begingroup\$ @Andyaka, I've added the full solution to the post -- if that gives additional context. \$\endgroup\$
    – Foobar
    Commented Sep 16, 2021 at 17:11
  • \$\begingroup\$ The voltages are added. However, in going round the loop in a consistent direction, one voltage has the opposite polarity to the other. What's (+50) + (-20)? \$\endgroup\$
    – Neil_UK
    Commented Sep 16, 2021 at 17:13
  • \$\begingroup\$ @Andyaka, ok I think I've figured it out. The voltages are series opposing since the (+) signs are facing each other. 50 - 20 = 30 V. V = I / R = 30 / 3 = 10. However, the sign is negative since it's asking us to find the current flowing clockwise, but in reality the current is flowing counter-clockwise. \$\endgroup\$
    – Foobar
    Commented Sep 16, 2021 at 17:18
Try to analyze this equivalent circuit
As you can see from node A to B we have a voltage rise by 20V and from B to node C we have a voltage drop by 50V. Therefore V_CA = +20 - 50V = - 30V.
