I have designed a POE device where I used the MAX17690 flyback converter to implement an isolated PSU for my device. I used the reference design MAXREFDES1105 (5V/2A design) from Maxim to size the circuit. I used same nominal value components in my design. Previously the operation was tested on MAX17690 evalboard.
First Issue: I think the circuit is too hot for normal operation. At secondary side the board temperature is about 50-60°C with ~400mA load. At primary side it is 45-50°C. On evalboard, with same load, at secondary side it is like 40-45°C, primary side it is ~30-40°C.
For some resistors I used 5% resistors instead of 1%. Can it cause the issue?
I am not using the PSU on the rated current, can that be the problem?
Second issue: The POE interface controller dies after the first successful operation when I remove the Ethernet cable. So for the first plug-in, it works nice, after the second try the Network Switch does not recognize the device and POE supply is not starting. It works only if I replace the controller.
I am using a QFN package of LTC4257IDD-1#PBF. If I solder the LTC4257CS8#PBF, SOIC8 package, with air wires, it works well after multiple connection/disconnection of ethernet cable. With QFN package with the same wiring it does not..
Am I missing any protection circuit, or capacitor in the POE interface circuit?
Or am I just messed up the Layout?
