I was reading this Article regarding the pull up resistor calculation.
I understood that the value of the pull up resistors depend upon the currents, the supply voltage and the Logic Level voltages between the master and the slave. Is there anything else on which the resistor values depend upon?
I had this thought like, suppose in one configuration, the I2C Master is close to the slave. And in another configuration, the I2C master is away from the slave. So, in both the cases, would the pull ups be the same value ? If not, why?
