I am reading through this document by TI on designing a temperature sensing circuit with an NTC thermistor. I'm having some trouble understanding the design steps though. Here are some snippets from the application note: -
They state that they want the op-amp to operate in the linear region which I guess means that they don't want the op-amp output voltage to exceed the supply voltage (saturation). For that, they need a certain value of \$R_1 \$ to limit the input voltage. However, in their calculation they don't take the supply voltage into account at all, but only use the min and max value of the thermistor.
My question is how can they neglect the op-amp's supply voltages when calculating \$R_1 \$? And also, why do they calculate it like this \$R_1 = \sqrt{R_{NTC,max}\cdot R_{NTC,min}} \$?
Why is it not, for example, \$R_1 = \frac{R_{NTC,max}+R_{NTC,min}}{2} \$?
VDD
is supplying both, the op-amp and the NTC network you cannot exceed the op-amp's positive rail. \$\endgroup\$
