I am wanting to use a 5x2 IDC connector in my project which are quite common. Most IDC connectors such as this one don't have a footprint or symbol. Which one do I use? Can I use any 5x2 connector provided it has the correct pitch i.e 2.54 mm in this case?
1 Answer
Some parts instead of having a single datasheet have an additional sheet with a drawing. If you scroll down the page you'll see it. It has the information you need to create a footprint.
Your PCB editing software should have a function to create custom footprints. If you're just starting out you may be surprised how often this is required.
\$\begingroup\$ I see, thank you. Man seems like a lot of effort for something that universal \$\endgroup\$– yoltCommented Jan 5, 2022 at 7:54
\$\begingroup\$ Yeah it's annoying but you get used to it. You should be able to bang out a footprint for something like this in a couple of minutes once you get the hang of it. \$\endgroup\$– DrewCommented Jan 5, 2022 at 9:11
