I wrote the next code in quartus 15.0, where I show what I want to do for a specific project. I can write it both in VHDL and Verilog HDL, but verilog is notoriously shorter.
module TOP(
ONCHIP_RAM_verilog #(
.ADDRESS_WIDTH (16),
.DATA_WIDTH (64),
.INIT_FILE ("FIS_ROM.mem")) //ANY FILE
u_rom(
.CLK (CLK),
.WRT ( ),
.ADDRESS (my_address),
.DATA_IN ( ),
.DATA_OUT (my_data)
endmodule
module ONCHIP_RAM_verilog #(
ADDRESS_WIDTH = 8,
DATA_WIDTH = 8,
INIT_FILE = "MEM.mem")
input wire CLK,
input wire WRT,
input wire [ADDRESS_WIDTH-1:0] ADDRESS,
input wire [DATA_WIDTH-1:0] DATA_IN,
output reg [DATA_WIDTH-1:0] DATA_OUT
//THIS WON'T BE BUILT IN THE ON-CHIP MEMORY,
//BUT WITH LOGIC ELEMENTS INSTEAD
//initial begin
// $readmemh (INIT_FILE, my_mem);
//end
//BECAUSE I AM USING A MAX 10 FPGA
(*ramstyle = "M9K"*)reg [DATA_WIDTH-1:0] my_mem [(2**ADDRESS_WIDTH)-1:0];
// /*synthesis ramstyle = M9K*/; other option
always@(posedge CLK)begin
if (WRT)begin
my_mem[ADDRESS] <= DATA_IN; //write
end
DATA_OUT = my_mem[ADDRESS]; //read
end
endmodule
Where I define my simple module/entity ONCHIP_RAM, which in normal circumstances -as a RAM- works perfectly fine, I define its size in the TOP module and it stores data normally. If I would like to build a ROM, I could easly not use the WRT and DATA_IN wires, but the initialization from the file INIT_FILE won't build the on-chip memory, instead it will build my ROM from logic elements, and as I need larger rom's my resources get limited.
I know I can build a ROM in the Qsys tool from Quartus, but I would really like to use HDL only because my project can easly change from an altera to a xilinx dev board. This is also true for the altsyncram file which bassically solves my problems, because I did some tests with that file, but I doubt it will work on ISE or Vivado.
I also get message 276014 and (276013): RAM logic "ONCHIP_RAM_verilog:u_ram_verilog|my_mem" is uninferred because MIF is not supported for the selected family which does not appear when I use Qsys and the altsyncram file, for which I think quartus does write the on-chip rom in the programming file, meaning part of my problem might be with the software configuration.
I hope you could help me and thanks in advance.
