I recently received a cheap (and probably non CE-certified product) that is capable of charging a few 18650 cells. I use it to charge recycled cells before decharging them to measure capacity. However, I found that the charger charges my batteries to 4.27 volts, a meaningful bit higher than the 4.2 volts that is usually regarded as a common lithium-ion chemistry maximum. I never leave the charger unattended, especially now that I have seen this interesting no-load voltages. I know there exist special more expensive cells that are specified to go up to 4.35 volts, but these can not be assumed to be.
So, would there be any danger because - or any damage done to - charging normal 18650 lithium-ion cells to be around 4.27 volts at no load? The batteries seem to even keep such a voltage over the few days that they've been sitting around.
