I have a camera that connects to USB2.0 Type A I would like to connect it to my laptop that has a USB Type C receptacle..
I can't use a converter.
What is the wiring diagram for this solution?
I have welded the camera's D+, D-, Vbus and GND into Type-C cable using Type-C pinout diagram but when I connect it to my laptop the camera shuts down after a few seconds. If I add a converter (Female C to Male A) to this cable and plug it to a Type A connection on my laptop it works with no issues.
Any advice?
    \$\begingroup\$ Just FYI, you didn't "weld" the wires, your "soldered" them. \$\endgroup\$
    – brhans
    Commented Feb 9, 2022 at 14:21
The parts that tell the laptop what kind of device has been plugged (a device, a charger, something else like a display or docking station) are missing.
Most likely you just need individual 5k1 resistors to ground on the each CC pin, but do verify yourself.
  • \$\begingroup\$ I've soldered the resistor, it works thank you! \$\endgroup\$
    – Gal Magen
    Commented Feb 10, 2022 at 5:15
