I plan to use the ESP-12E's GPIO pin to dim a 12 V LED strip wire and control a 5 V [WS2812B] 1 panel via CAT 5.
I tried using a 10 ft CAT 5 cable to link the ESP12E pin to the DIN pin on the WS2812B panel, however, the LED panel did not change color.
When I tried to dim a 12 V LED by sending a signal to a MOSFET (IRFZ44N)via a 10 ft CAT 5 wire, the identical problem occurred. When I tried to dim it, nothing occurred.
I believe the issue is that the signal sent by ESP212E is insufficient to reach my devices.
What I can do to make the signal from ESP12E reach the WS2812B and the MOSFET through a 10 ft CAT5 cable?
Or what can I do to control both of my devices from a long-distance?
Here is my schematic:
- Din: Connect to DIN WS2812B
- LEDDIN: PWM pin dim 12 V led
- I use LM7805 to convert 12 V dc to 5 V DC to power ESP8266
- 12 V-out to power 12 V LED
Part Detail:
- 2x WS2812B panel (8 x 32) : 512 LEDs WS2812B Panel
- 3 ft 12 V LED strip: 12 V white warm LED strip
- 1x ESP12E
- 1x LM7805: LM7805
