In the following picture captured from the book Practical Electronic for Inventors, it mentioned that there will be a huge negative voltage spike when the switch is suddenly switched off.
According to the blog here, the negative spike is due to the Ohm’s law: V=IR and as R is going to be very huge (the resistance of the air), given that the current should still be the same in the loop, so the voltage difference between the point prior to the inductor and the ground should be negative in order to conform to KVL (voltage source gain(battery)+ voltage drop in the gap (switch) + voltage gain in the inductor = 0).
In the picture, the voltage waveform also shows that after the negative voltage spike, it revives to positive and then drops to negative again, over and over until the energy dissipates.
My question is, why does the voltage revive back to the positive after the first negative voltage spike? And why is there a second and even the following negative damped spikes?
