After looking at several circuit diagrams and their actual implementation, I found that the position of the parts is not considered in the diagram. Is there any reason for this?
If all parts are arranged on a flat ground (i.e. 2D) would it be theoretically possible?
I clearly see the problem if the parts are organized in a 3D structure (e.g. a machine) but not in a 2D way.
What is the right type of diagram that provides a circuit diagram with the corresponding position?
Mostly all the components of the machine that I want to represent are relatively simple ones (motors, compressors, sensors etc.) and connected directly to the inputs and outputs of one controller. This means there is nothing between controller and component. What is the value of using a circuit diagram instead using a simple table?
