Hey guys I am designing a LNA biases by a 3.3 V source and tuned to 2.5 GHz.
Here is the schematics, the testbench and some results (s parameters analysis). I would like to know if there is a way of increasing the gain and decreasing the noise factor of my amplifier. Thank you.
[![enter image description here][1]][1]
So in case values are not visible this LNA is made of:
- An input resonance between a 4.7 nH inductor and a 400 nF capacitor -> tunes it to 2.5 GHz.
- A biasing resistor of 6.67 kohm. VGG is obtained as half of VDD by those rightmost ressitors of also 6.67 kohm.
- A MOS transistor with L=0.35u and W=200u.
- A load inductor of 4.7 nH.
- A DC decoupling capacitor of 5 pF.
[![enter image description here][2]][2]
On the testbench the 3.3V source is visible. The inductors of 500pH are to simulate pads inductance. The capacitor of 1mF is just for DC decoupling when obtaining the DC bias point
Simulations:
S11 (red curve) gives if the amplifier is matched or not (it it is under -15 dB) -> -20.488 dB
S21 (yellow curve) gives the gain. If it is above 10.5 dB is good -> 11.396 dB (good but I wish it was better).
S22 (pink curve) below 0 dB to gurantee stability (positive real part impedance) -> it checks out
Noise Figure (blue curve) just a little above 3 dB -> this is where things are a bit bad with a noise figure of 4.3 dB
I also see a strange zone where NF and S21 vary a lot around 4 GHz? Why is that?
Any opinions?
Thank you!
