I am learning electronics and needed a negative rail. I have two transformers that have the same rated input/output voltages but different power ratings and manufactured by different companies.
Transformer 1: Input 230VAC, Output: 20VAC, Power Rating: 100W.
Transformer 2: Input 230VAC, Output: 20VAC, Power Rating: 25W.
The higher powered transformer (100W) I used for the positive rail and the lower powered (25W) transformer I used for the negative rail.
Everything seemed OK under no load but then I added an LM7905 to the negative rail and found that the regulator could not regulate the voltage. The voltage output of the LM7905 slowly goes up (i.e. progressively gets less negative).
If I just use the 100W transformer, center tapped (+/-16V no load), for the same circuit the regulator regulates the voltage no problem.
By the way, I was not going to exceed 1.25A from the negative rail to ground or exceed 5A from the positive rail to ground.
Please see schematic below.
So I actually have three questions:
Is it OK to put in series (secondary coils) two transformers with the same rated input/output but different rated power? Why or why not?
Why is the regulator unable to regulate the voltage properly in this scenerio?
