In a cathode ray tube or electron gun, electrons liberated from the cathode by thermal emission accelerate towards a ring-shaped anode, from the potential difference between cathode and anode.
If an electron is slightly off-centre, so nearer to one edge of the anode ring than the other, I'd expect the near side of the anode ring to attract it more than the far side, pulling it further off centre (because electrostatic force follows the inverse square law)
So I'd then expect most electrons to end up hitting the anode ring, rather than going through.
Why do electrons go through the hole instead of hitting the ring? Is it z-pinch keeping the beam together, or does a complicated arrangement of anodes at different voltages lead to an inward radial force, and if so how? I'd expect any anode to attract electrons towards itself, moving the beam further from the centre for any anode that's on the outside of the beam.
