I'm considering buying this unit for backup energy + solar charging:
https://www.ecoflow.com/us/delta-pro-portable-power-station
Now, the max input is 1600W with 150V and 15A max. This is acceptable if the sun shines bright and I'm getting the 1600W into the system. However, that is obviously not always the case. You need to overdesign your solar array to get an average of 1600W into your system due to cloud overage etc... Thus, my problem is I cannot connect 150V, 30A setup to the device as it could potentially blow a fuse or not be compatible.
Is there anything that can be done upfront to accept higher amps, and discard anything above 15A? So that I only feed 15A into the power station? Throw away any excess energy? Maybe put a Victron solar charge controller and feed that into the power bank? I know this is a long shot, just asking if something like this is possible?
