I have question regarding SPI termination when using three-state buffers:
- Do we need termination resistor from master to three-state buffers (since ICs are very close)
- If we do, then do calculate the trace impedance from three-state buffer to master or slave to master.
- How MISO where you put termination resistor (close to slave or buffer)
- Do we even need termination resistor since max trace space is around 20 cm.
Let assume we have below setup which we have two 3.3 V slave. Note: OE is enabled for all channels. (74LVC126)
Please let me know if drawing is not clear or you need more information.
Base on Jens answer
