I was trying to read a .csv file and use its contents. The csv is formatted as:
0001,1010,1110
0101,1100,1001
My code is:
`timescale 1 ns/10 ps
module tb;
    reg a, b;
    reg[3:0] r1;
    reg[3:0] r2;
    reg[3:0] r3;
    integer i, f, j;
    initial
    begin
        f = $fopen("vec.csv", "r");
        for (i = 0; i < 2; i = i +1)
        //while(! $feof(f))
        begin
            j = $fscanf(f,"%b %b %b",r1,r2,r3);
            #20;
        end
        $display("%b,%b,%b", r1, r2, r3);
        $fclose(f);
        $display("pass");
    end
endmodule
The output is:
0001,xxxx,xxxx
0001,xxxx,xxxx
pass
It seems that it can't read anything besides the first 4 bits of the 1st line. Could you tell me what I am doing wrong?
Try inserting commas ,
      j = $fscanf(f,"%b,%b,%b",r1,r2,r3);
  • \$\begingroup\$ Thanks, what if there was 20 or more sets of 4 bits in every row? should I keep writing %b,%b,%b,.... for 20 times. is there a better way to do this? \$\endgroup\$ Aug 4, 2022 at 4:15
  • \$\begingroup\$ This is almost a completely new question. If you know exactly how many values are on each line, you can use $fscanf to read one value at a time in a loop. Otherwise you can read one line at a time using $fgets and then split the line into an array of values. This would be much easier to do in SystemVerilog using a package like SVlib. \$\endgroup\$
    – dave_59
    Aug 4, 2022 at 14:59
