I'm using the MCP23017 16-bit I2C GPIO Expander in combination with the microcontroller PIC18F47J53. Both products are from Microchip.
I use MCC (MPLab Code Configurator) to configure the hardware modules in the microcontroller. For I2C, I'm using MSSP2 in Master mode at 400kHz, not using interrupts. SCL is on pin D0 and SDA is on pin D1.
I configured both PortA and PortB on the MCP23017 as inputs using weak pull-up resistors. I then read both GPIOA and GPIOB, which are connected with simple push buttons to ground, on regular basis.
All works fine! But the weird thing is that after receiving a byte from the MCP23017, I need to send a NOT Acknowledge (NACK) instead of an Acknowledge (ACK) before sending my Stop sequence, otherwise my SDA line seems to be pulled down by the MCP23017 locking my I2C bus for ever.
The specifications of the GPIO expander don't mention anything about having to use a NACK (I'm using Byte mode):
Although my application works perfectly, I wonder if somebody has an explanation for this?
For completeness, here is my code - you find the NACK at then end - I have marked it with "THIS NEEDS TO BE NACK OR IT WON'T WORK":
/* * A library for controlling MCP23017/MCP23009 via I2C * Copyright (c) Microchip MASTERs Conference 20047 SER2 * Practical I2C - Introduction, Implementation and Troubleshooting */ #include "xc.h" #include "stdbool.h" #include "stdint.h" #include "I2C_GPIO.h" void InitGPIO(void) { SSP2CON1bits.SSPEN = 1; WriteByteGPIO(0b01001110, 0x00, 0xFF); // IODIRA = all inputs WriteByteGPIO(0b01001110, 0x01, 0xFF); // IODIRB = all inputs WriteByteGPIO(0b01001110, 0x0C, 0xFF); // IODIRA = all pull ups WriteByteGPIO(0b01001110, 0x0D, 0xFF); // IODIRB = all pull ups } void WriteByteGPIO(char SlaveAddr, char RegAddr, char Data) { // Start SSP2CON2bits.SEN = 1; // Initiate Start condition while (SSP2CON2bits.SEN); // Wait for Start condition to complete PIR3bits.SSP2IF = 0; // Clear SSP Interrupt Flag // Slave Address SSP2BUF = SlaveAddr; // Send the Slave Address and R/W bit kept to 0 while (!PIR3bits.SSP2IF); // Wait for Acknowledge. SSP2IF is set every 9th clock cycle. PIR3bits.SSP2IF = 0; // Clear SSP2 Interrupt Flag if (SSP2CON2bits.ACKSTAT) { SSP2CON2bits.PEN = 1; // Initiate Stop condition while (SSP2CON2bits.PEN); // Wait for Stop condition to complete return; // Exit } // Register Address SSP2BUF = RegAddr; // Send the Register Address while (!PIR3bits.SSP2IF); // Wait for Acknowledge. SSP2IF is set every 9th clock cycle. PIR3bits.SSP2IF = 0; // Clear SSP2 Interrupt Flag if (SSP2CON2bits.ACKSTAT) { SSP2CON2bits.PEN = 1; // Initiate Stop condition while (SSP2CON2bits.PEN); // Wait for Stop condition to complete return; // Exit } // Send Data SSP2BUF = Data; // Send the Data while (!PIR3bits.SSP2IF); // Wait for Acknowledge. SSP2IF is set every 9th clock cycle. PIR3bits.SSP2IF = 0; // Clear SSP2 Interrupt Flag if (SSP2CON2bits.ACKSTAT) { SSP2CON2bits.PEN = 1; // Initiate Stop condition while (SSP2CON2bits.PEN); // Wait for Stop condition to complete return; // Exit } // Stop SSP2CON2bits.PEN = 1; // Initiate Stop condition while (SSP2CON2bits.PEN); // Wait for Stop condition to complete } char ReadByteGPIO(char SlaveAddr, char RegAddr) { char TempData; // Start SSP2CON2bits.SEN = 1; // Initiate Start condition while (SSP2CON2bits.SEN); // Wait for Start condition to complete PIR3bits.SSP2IF = 0; // Clear SSP Interrupt Flag // Slave Address SSP2BUF = SlaveAddr; // Send the Slave Address and R/W kept to 0 while (!PIR3bits.SSP2IF); // Wait for Acknowledge. SSP2IF is set every 9th clock cycle. PIR3bits.SSP2IF = 0; // Clear SSP2 Interrupt Flag if (SSP2CON2bits.ACKSTAT) { SSP2CON2bits.PEN = 1; // Initiate Stop condition while (SSP2CON2bits.PEN); // Wait for Stop condition to complete return 0xFF; // Exit } // Register Address SSP2BUF = RegAddr; // Send the Register Address while (!PIR3bits.SSP2IF); // Wait for Acknowledge. SSP2IF is set every 9th clock cycle. PIR3bits.SSP2IF = 0; // Clear SSP2 Interrupt Flag if (SSP2CON2bits.ACKSTAT) { SSP2CON2bits.PEN = 1; // Initiate Stop condition while (SSP2CON2bits.PEN); // Wait for Stop condition to complete return 0xFF; // Exit } // Restart SSP2CON2bits.RSEN = 1; // Initiate Restart condition while (SSP2CON2bits.RSEN); // Wait for Restart condition to complete PIR3bits.SSP2IF = 0; // Clear SSP Interrupt Flag // Slave Address SSP2BUF = SlaveAddr | 1; // Send the Slave Address and R/W set to 0 while (!PIR3bits.SSP2IF); // Wait for Acknowledge. SSP2IF is set every 9th clock cycle. PIR3bits.SSP2IF = 0; // Clear SSP2 Interrupt Flag if (SSP2CON2bits.ACKSTAT) { SSP2CON2bits.PEN = 1; // Initiate Stop condition while (SSP2CON2bits.PEN); // Wait for Stop condition to complete return 0xFF; // Exit } // Receive Data SSP2CON2bits.RCEN = 1; // Receive the Data Byte from Slave while (!SSP2STATbits.BF); // Wait for the Receive to complete TempData = SSP2BUF; // Save the Data Byte // Acknowledge SSP2CON2bits.ACKDT = 1; // Prepare to send NACK --- THIS NEEDS TO BE NACK OR IT WON'T WORK SSP2CON2bits.ACKEN = 1; // Initiate NACK while (SSP2CON2bits.ACKEN); // Wait for NACK to complete // Stop SSP2CON2bits.PEN = 1; // Initiate Stop condition while (SSP2CON2bits.PEN); // Wait for Stop condition to complete return TempData; }
