I have a project where I need a small coupled inductor for isolated low baudrate communication. The line is short and I don't really care if only half of signal goes through.
I need it really cheap, below $0.10 at 10k quantities. Problem is, coupled inductors don't really fit in my budget.
So I've found this common mode choke, presumably used to filter high speed communication lines:
DLM0NSM900HY2
My application requires isolation of at least 80V. I am looking at the the specs of this choke and it is not clear what voltage it will hold, and what inductance I should expect.
Can someone comment on that?
