Context: I am trying hook up the TI CC26X2R1 dev board to a 5 wire load cell to act as an end device in a Thread network. I use the Sparkfun HX711 load cell amp to amp and as an ADC (links for both below).
Question: the I2C address is a required parameter for setting up I2C on the CC26X2R1, but I am not able to get the I2C address of the Sparkfun Hx711 using any of the standard I2C scanner programs for Arduino. Am I missing something? Shouldn't the HX711 have an I2C address?
If not apparent already, I am relatively new to this, so thanks in advance!
Load cell CC26X2R1 Sparkfun HX711
The HX711 doesn't have an I2C interface. No interface, no address.
It has a serial interface, that can be read as SPI.
As very few bits need to be programmed, it doesn't have a data line going to the HX711, it instead counts the clock pulses used to read the data out, and switches inputs based on the number received. A clever trick, which saves a package pin.
