I am planning on boondocking on my RV and am in the phase of designing the system and want to stay at 12 V. I have found the perfect solar panels for it, but the specs make them somewhat odd to wire:
Quantity: 4 panels
Rated Power (Pmax): 200 W
Voltage at Pmax (Vmp): 63.8V
Current at Pmax (Imp): 3.2A
Short-circuit current (Isc): 4.1 A
Open-circuit voltage (Voc): 96.0 V
I have two 12 V, 200 Ah LiFePO4 batteries in parallel to run my 12 V inverter. To stay in budget I was thinking if it would be OK to have the battery bank wired in series and parallel at same time so I can discharge them at 12 V and charge them at 24 V to increase the power I can run on the same charge controller.
Edit: Something like this example but I think they are charging at 36v a battery bank of 72v
