I have found this PFC controller (I am building a rectifier to ~500V). As I understand, because PFC uses a boost converter, it should be able to boost rectified voltage to bigger voltage. How would I set this voltage? Do PFC controllers have such ability? Or do they just make output ~325V (from 230V AC)?
1\$\begingroup\$ Designers usually select a boosted voltage slightly above the maximum peak value of the input line. This is because the less you boost, the best the efficiency. Therefore, if your mains is 265 V rms as a max, it is not uncommon to find regulated voltages at 380 V dc for instance, 400 V being a maximum. Also, some designs include a boost follower mode where the regulated dc voltage changes with the input voltage, again to maximize efficiency: 250 V dc from 85 to 150 V rms and 380-400 V beyond. Some circuits do that automatically, some externally by altering the resistive division ratio. \$\endgroup\$– Verbal KintCommented Nov 27, 2022 at 11:09
\$\begingroup\$ On top of what @VerbalKint said, electrolytic capacitors peak at 400 V (price/performance), so going above 400 V DC for a 85-265 V AC input device becomes suboptimal. \$\endgroup\$– winnyCommented Nov 27, 2022 at 11:22
\$\begingroup\$ Also - could PFC controllers deal with not perfect sinusoidal input? If it is in poor quality (amplitude top is chopped by other non-PFC rectifiers)? \$\endgroup\$– Ri DiCommented Nov 27, 2022 at 19:15
Add a comment
1 Answer
Your device can modify the boosted value by adjusting the resistor ratio in red: -
The set voltage has to be larger than the peak AC voltage else you won't get a pseudo-resistive current being drawn from the AC line.
I'm not saying that all PF controllers are like this (because that would be an exhaustive study). However, most that I have seen have this ability.
