Circuit reference from Analog Devices
The above circuit produces the correct output in simulations (Proteus and Altium).
When the circuit is built on the board, the first stage produces the correct output, but the second-stage op-amp can't equalize the inputs.
In a test: non-inverting input 20.3 V, inverting input 15.7 V, op-amp output 0.1 V (th is 2.1).
Also used:
- ISP25DP06NMXTSA1 P-channel MOSFET (Vgs threshold 2.1 V, Rds(on) 250 mΩ).
- 220 Ω for R3 and 100 Ω for R6 (they are current sense resistors - 1 W).
- LT1491A op-amp (4-ch).
What is the reason why the second-stage op-amp can't produce the correct output?
