If I have an LED lamp which is specified as, say, 350 mA at 12 V DC, what would happen if I fed it directly from a 48 V DC constant-current power supply capable of providing up to 350 mA?
I understand increasing the voltage on an LED lamp typically makes it run hotter as it tries to draw more current, but since it is fed by a current limited source is this issue voided?
Edit: I am talking about higher-powered LED lamps, like ones used for outdoor lighting such as streetlights, garden lights, etc. Say a maximum wattage of 30 W.
48VDC constant current power supply providing 350mA
would not necessarily output 48 V ... it would output a voltage that is necessary to push 350 mA through the load \$\endgroup\$
