I have an AC generator of 6 VAC and 9 W power output. It is on an old bicycle motor, a BSA winged wheel. I intend to run NiceLite 3-6 VDC LED lights rated at 1 W each, one red and one white.
I appreciate I can use Schottky diodes to make a bridge rectifier to convert the AC. I also need the option of holding the energy charge into capacitors or batteries to give me stationary lights when the engine isn't running or I run out of fuel and end up cycling along at night time.
I realise I could use a switch to go between generated output and stored energy, but automatic switching employing the right transistor could be utilised.
