I have two different MOSFETs controlling an actuator that is specified to have a current draw of 13A. There is also a note on the actuator datasheet about inrush current stating:
Typically, the inrush current will last between 75 – 150 milliseconds and can be up to three times higher than the current for the actuator and load
When choosing a heatsink to keep the component cool, do I need to consider the inrush current or is it okay to use the max current of 13A for the heat calculations? What is the method of determining how much the MOSFET increases in temperature as a function of time?
Here are the datasheets for the MOSFETs under question:
https://assets.nexperia.com/documents/data-sheet/PHP29N08T.pdf
https://www.infineon.com/dgdl/irf4905pbf.pdf?fileId=5546d462533600a4015355e329b1197e
