I'm using this MCP73831 device.
I want to know how what to expect as a voltage level on the STAT pin when the below chart on page 13 says, STAT = HIGH & STAT = HIGH-Z.
When the charging is completed, I need to see HIGH voltage (say if Vdd is 5V, then HIGH would indicate 5V) 5V on the pin, as it is mentioned as HIGH.
When it is mentioned as high-Z state, then also, I will see the same 5V, right?
How can I differentiate between high and high-Z state?
This charge complete mode would also mean the same when there is no battery connected to Vbat right? So, when charging is complete or the battery is disconnected, then the STAT pins would show the same result, right?
