I wrote VHDL to instantiate some RAM (256 bytes) using BRAM on a Digilent BASYS 3 FPGA development board using Vivado design tools. It takes 8 bits as the data input and outputs 8 bits on the output. A write to RAM is synchronous and performed on the rising edge when store (write) input is high. Read from output port is always performed by forced to zeros if the enable signal is high with AND gates.
My issue is that the RAM output is always zeros. Even if I define all 256 bytes as 0xFF (others => 0xFF) the output is still zeros. Can anyone see the problem here?
Code is as follows with a simulation and :
Code
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.NUMERIC_STD.ALL;
entity Random_Access_Memory is
Port (D_i : in std_ulogic_vector(7 downto 0);
Addr_i : in std_ulogic_vector(7 downto 0);
Clock_i : in std_ulogic;
Store_i : in std_ulogic; --Active low input
Enable_i : in std_ulogic; --Active low input
Q_o : out std_ulogic_vector(7 downto 0);
Addr_in_temp_o : out integer range 0 to 255
end Random_Access_Memory;
architecture Behavioral of Random_Access_Memory is
type RAM_ARRAY is array (0 to 255) of std_ulogic_vector(7 downto 0);
signal RAM : RAM_ARRAY :=
-- 0 => "00000001",
-- 1 => "11111111",
-- 2 => "00010000",
others => "11111111"
signal Addr_in_temp : integer range 0 to 255;
signal D_in_temp : unsigned(7 downto 0);
signal D_out_temp : std_ulogic_vector(7 downto 0);
begin
Process(Clock_i, Addr_i)
begin
if(rising_edge(Clock_i)) then
if(Store_i = '0') then
RAM(Addr_in_temp) <= D_i;
end if;
end if;
end Process;
Addr_in_temp_o <= Addr_in_temp;
Addr_in_temp <= to_integer(unsigned(Addr_i));
D_out_temp <= RAM(Addr_in_temp);
Q_o(0) <= D_out_temp(0) and (not Enable_i);
Q_o(1) <= D_out_temp(1) and (not Enable_i);
Q_o(2) <= D_out_temp(2) and (not Enable_i);
Q_o(3) <= D_out_temp(3) and (not Enable_i);
Q_o(4) <= D_out_temp(4) and (not Enable_i);
Q_o(5) <= D_out_temp(5) and (not Enable_i);
Q_o(6) <= D_out_temp(6) and (not Enable_i);
Q_o(7) <= D_out_temp(7) and (not Enable_i);
end Behavioral;
Testbench
library IEEE;
entity Top_tb is
end Top_tb;
architecture Behavioral of Top_tb is
component Random_Access_Memory is
end component;
signal D_i_tb : std_ulogic_vector(7 downto 0);
signal Addr_i_tb : std_ulogic_vector(7 downto 0);
signal Clock_i_tb : std_ulogic;
signal Store_i_tb : std_ulogic;
signal Enable_i_tb : std_ulogic;
signal Q_o_tb : std_ulogic_vector(7 downto 0);
signal Addr_in_temp_o_tb : integer range 0 to 255;
constant clock_period : time := 10 ns;
begin
DUT : Random_Access_Memory
Port map (D_i => D_i_tb,
Addr_i => Addr_i_tb,
Clock_i => Clock_i_tb,
Store_i => Store_i_tb,
Enable_i => Enable_i_tb,
Q_o => Q_o_tb
Clock_Gen : Process
begin
Clock_i_tb <= '0';
wait for clock_period/2;
Clock_i_tb <= '1';
end process;
D_i_tb <= "00000000";
Addr_i_tb <= "00000001";
Store_i_tb <= '0';
Enable_i_tb <= '0';
end Behavioral;
Simulation Waveform
check for a1
instead of a0
? \$\endgroup\$
