Are ADC errors like DNL, INL, Offset Error, Gain Error and Noise specs given in data sheets RTI or RTO? The units are LSB so it makes me think they are RTI.
3\$\begingroup\$ I assume by "RTI" and "RTO" you mean "relative to input" and "relative to output", respectively. Given that an LSB only makes sense on the output side of an ADC, would a measure in LSB be relative to the input or the output? \$\endgroup\$– TimWescottCommented Feb 5, 2023 at 17:16
Add a comment
1 Answer
Linearity and gain errors are the same on input or output, so it doesn't matter.
For Offset and noise, it depends on the given units. When in Volts, it is RTI. When in bits, it is RTO.
\$\begingroup\$ If an ADC error like offset error is RTO then can it be mapped to the input through LSB x Vref/2^N \$\endgroup\$– EfanaticCommented Feb 6, 2023 at 1:28
