I have a standing desk, which has a separate control board consisting of 7 buttons and 3 digit, 7-segment display. The controller is connected to the rest of the system via 8 cables.
Inside the controller there are following two chips:
First is what I believe a driver for the display. AD1650 chip
The second one though had me scratching my head: MN99L2 chip
This chip has 4-wire connection to the microprocessor, controls the display driver, and on top of that handles 5 of the 7 buttons (the last two buttons are connected directly, bypassing those chips)
Do you know what any of those chips are? And if possible even have a link for datasheet?
Probably way late for you, but I found this in search trying to track down the same thing. What brand is your desk?
I believe your second IC should be identified by the 019A number. It is probably a GeneralPlus GPM8F1129/1065/1033/1019A. The 103 page datasheet is available on https://www.alldatasheet.com.
  • \$\begingroup\$ Nice find, this indeed matches. The desk is a noname overseas export, nothing branded. \$\endgroup\$
    – jnovacho
    Commented Jul 3 at 8:32
The AD1650 is most probably some kind of clone of TM1650, which is LED Drive Controller / Keyboard Scan ASIC some info http://www.datasheetcafe.com/tm1650-datasheet-led-controller/
The chip connections match, the only difference I was able to find is, that on the AD1650 in my photo, the SCL and SDA are swapped, compared to TM1650.
The other chip will then be some dedicated ASIC/micro which provides the unknown protocol on one side and emits I2C on the other.
