I'm configuring I2C on a PIC18 using the built-in functions of the C18 compiler as described in section 2.4 of the documentation:
void OpenI2C2( unsigned char sync_mode,
unsigned char slew );
I'm not sure what I should do with slew
. I can choose from two options, defined in i2c.h
SLEW_OFF
: Slew rate disabled for 100 kHz modeSLEW_ON
: Slew rate enabled for 400 kHz mode
In the datasheet in register 15-1, page 257, the two options are explained in a bit more detail:
- 1 = Slew rate control disabled for standard speed mode (100 kHz and 1 MHz)
- 0 = Slew rate control enabled for high speed mode (400 kHz)
I don't understand it though - I have a couple of questions:
What is slew rate?
For me, the two options don't make sense - what if I'd want to disable the slew rate for 400kHz and enable it for 100kHz? Why is this?
When should I choose
SLEW_OFF
and whenSLEW_ON
