Does this circuit have to be implemented with a DW01A battery protection IC and a FS8205A dual MOSFET IC?
I want to make a simple circuit doing only the charging function of an 18650 battery.
The TP4056 has its own charging function, and it seems to be sufficient on its own.
I also read a blog saying that most commercial boards implementing these circuits are not well designed and do not use the DW01 circuit correctly.
I then asked myself the question of being satisfied with a TP4056 circuit alone in a context where I just want to make a simple load circuit.
The batteries will not be used at the same time. They will just be recharged and stored.
