Let's start off by saying I know just about nothing about electronics, thus the reason I am here.
I have a project I have been working on for a while. Although I have jury rigged earlier versions of this project in the past I am looking for the "correct" way to do it now.
If you look at my avatar you can see what I am doing. I am "attempting" to use the phantom power from a mixer to illuminate my custom built microphones.
The power source is my Mackie Mixer (or any other amplifier/mixer that supplies phantom power for use with condenser micorphones.) Since I am using dynamic microphones I do not need this phantom power for the microphone to work thus I am looking to repurpose it for some LEDs.
In the past I have used single LEDS each wired with a resistor and this worked, but that is too much wiring and way too complicated.
I have since found a few 12V LED modules which have 6 LEDs each and are so much easier to install and conceal in my mics.
The phantom power is 48VDC, but the current is only 30-40 milliamps. Because of that, I am able to light a single LED without blowing it even though they are usually only need about 3 VDC.
I have tried a few 12V LED modules. I currently (no pun intended) am trying a 12V 6 LED strip that is meant to be marker lights on a tractor trailer. It lights up and all but it is dimmer than it should be, I assume because of the low current.
Is there a way to up the current so they get brighter?
I hope I explained this right, like I said I really have no clue what I'm talking about.
This yellow one is the old style with 8 individual LEDs with resistors.
The present one is similar but dimmer. I can post a photo if needed but, visualize it as dimmer.
Lighted microphone:
48VDC was not my ideal power source but I've got to use what I've got.
The "old" way I did this I used resistors. When I noticed putting 4 LEDs in series worked all by themselves I stopped putting in resistors. I then made two circuits of four. I then took the XLR cable and connected the negative wires to the negative pin and each positive went to each of the other pins on the plug so as to keep any balance in either leg. No special LEDs, just your generic single yellow LED. The mic still functioned as normal. I couldn't hear any difference as long as the circuits were balanced. I did notice when all the LEDs were on one leg then it got very "tinny" sounding.
It is starting to look like I need to go back to individual LEDs and forget the ease of using a strip, even though it means many wires and trying to route them in the microphone to avoid seeing shadows cast. That was the big issue in my old style of making these.
I'm going to keep trying here. Any more input would be great and a simple solution will be fantastic.
These new LED strips are premade. They have resistors in them but I cannot see them as they are molded into the strip so the values are unknown. They are designed to work on a 12V circuit and there are six in each strip and I am using two strips, connecting them the same way as above so they are balanced. They are not getting as bright as when I test them with 12V.
