I'm using the following circuit to produce white noise. I'm applying 12V DC from a power supply. But my noise is very low - not at all amplified! I was expecting at least 100mV Vpp, but it's only about consistent 10mV Vpp.
From what I've seen from this link and this link I suppose it should be giving more amplification at the output than what I'm getting.
Is this the normal behavior of the circuit or am I missing something? What could I do to amplify the signal at the output without introducing op-amps (I was hoping T2 would gain a lot more)?
Thank you a lot!
I'm using 2N3904. But also tried with BC547 and BC3337. I also tried changing R1 to 48k ohms, with no result.
