I am researching about instrument amplifier circuit by use op-amp is LM358.
In this circuit gain is 1 by Rgain=R2=20k, R1=R3=10k.
Testing is define frequency range 1 Hz-10 kHz but when this circuit is tested on 10 kHz sine wave input, see figure below, vout is not correct same sinewave input.
In datasheet of LM358 bandwidth maximum at 1 MHz or 100 kHz. I have a question that in my range research LM358 can not working in instrument amplifier?
But when I am testing LM358 to be buffer input sinewave 10 kHz it is working correctly.
