What are the drawbacks/disadvantages of using a voltage regulator as a constant current source.
It is possible to create a constant current source from an adjustable linear voltage regulator by taking feedback across a sense resistor and passing that feedback to the ADJ pin of the voltage regulator, like so
For some use-cases this is perfectly fine. However, it has some significant drawbacks for other use-cases.
First, in addition to the voltage drop across the linear regulator itself, there must be a voltage drop across the sense resistor equal to the voltage required for correct operation of the ADJ pin. This is typically 1.25 volts. Now a constant current device is meant to have some voltage drop in order to regulate the current. However, in some cases the voltage drop for this circuit is too high for a particular application.
Second, if the current to be regulated is "high", then the power dissipated by the regulator, and by the sense resistor, will also be high. This will necessitate some form of heat removal. It may be advantageous to have only one pass element need heat removal measures rather than two. Sensing a large current through a resistor that has a 1.25 volt drop on it may require a beefy resistor, and possibly a heatsink. It may (or may not) be advantageous to sense the current with a smaller resistor and amplify the voltage to feed back to the linear regulator. Obviously if the current being regulated is small enough, this will not be an issue.
Third, many voltage regulators have minimum current requirements, and therefore are unsuitable if the current specification for the constant current source is less than the minimum for the voltage regulator.
I have taken your description of "using a voltage regulator to create a constant current source" to mean the simple circuit shown in my schematic.
But both of the issues I described for that circuit can be mitigated by making modifications to that circuit. So, unless we compare two different concrete circuits, any rule we lay out is subject to exceptions.
