This question is related to the LED component HL-AM-2835H489W-S1-08HL-HR3 from HONGLITRONIC. The datasheet for this part can be found here.
This component has a SMD2835 SMD package that I have not used before. Please see the footprint drawing given in the datasheet page 2.
The LED itself is fairly symmetrical when viewed from the top. However, the pads are not symmetrical. The only question is, where exactly should the mid point be in the PCB footprint while taking the tolerance into consideration. It seems that the mid point won't be in the gap between the two pads but rather on the right side pad.
