I am having a problem with my ATTiny85. I should mention I use Arduino as an ISP to program it.
My ATTiny worked fine until I decided that I need to step up the clock speed from 1MHz to 20MHz so I selected ATTiny85 at 20MHz from the Boards menu and then clicked on Tools>Burn Bootloader. But that was stupid, since now my ATTiny doesn't work at all. I cannot upload sketches on it and if I try I get this message:
avrdude: Yikes! Invalid device signature. Double check connections and try again, or use -F to override this check.
So my question to you would be, is there a way to reset what I have done? Or even better, to make it work at 20MHz?
Blink
example. If that works fine, you can return to your ArduinoISP (I believe that is the name of the programmer software you were using). \$\endgroup\$
