I'm looking at this data sheet: SCR data sheet on Digikey
This device seems perfect for what I want to do, with 1 exception:
The holding current is way too low.
Various forums have suggested that (on state current) = k * (holding current), where k is typically between 2 and 3. The factor of 2-3 seems absurdly low compared to the devices I have looked at. For instance, if you search for SCR on Digikey, the highest holding current is a small number of Amps (I see 2) while the on state current goes into the thousands.
What I really want is the holding current to be about 20% of the on state current.
Is there any way to modify the design of the SCR itself to achieve this? (As opposed to using an external transistor to shunt current around the SCR. I'm trying to eliminate external components.)
