I am beginner and trying to understand how to calculate the required resistance and required current in series circuits.
In this first picture I would like to know if my calculations are correct or not correct. I have an LED and a resistor connected to a 5V 500mA. The LED requires 5V and .30mA current. I need to know how much resistance I need. I did the following calculations.
Volt (V) = 5V
Current (I) = .03 Amps
R = V/I = 5V/.03 Amps = 166 OHMS.
In the calculations above I calculated a 166 OHM resistor would output 5 Volts with a current of .03 Amps if my calculations correct or not? If my calculations are not correct please correct them and explain your correction.
In the second circuit I would like to know how to calculate the total Amps required by all of the LEDs in the circuit. One LED requires 30mA, so I multiplied 30mA by 3 which is 90mA. Is this the correct why to know the Amps required by all the LEDs? If not please correct me and explain the correction.
Third question. I have 4 AA batteries. One AA battery outputs 1.5V and 2Amps. If I have 4 batteries does that mean I have 6V and 2Amps output?
