Does anyone know what footprint assignment for the potentiometer WH148 style in KiCad? There were a lot of footprints but I don't know which one is the same as the WH148 style.
Look in the datasheet for the WH148 pot to see the recommended footprint, then search through the footprints provided by KiCad to find a footprint that matches the datasheet. You will likely find some pattern to KiCAD's footprint names that will ease your search.
It may be easier to make your own footprint - if you do any amount of PCB layout work, you WILL have to make some of your own footprints.
If we take a look at the datasheet for the WH148 series, we can see that the recommended footprint is just 3 through-holes with a 5 mm pitch and a 1.2 mm diameter.
This is identical to the KiCAD footprint for the Alps RK163 (Potentiometer_Alps_RK163_Single_Horizontal).
enter image description here (Source: rs-online)
Keep in mind though that there are different shaft length available, so the silkscreen might not match the actual length.
