I am trying to find the error in my schematic. I want to use the TPS3840DL supervisor to reset (turn off and on again) the TPS54202 step-down converter either when the voltage drops below the threshold or a manual reset is present (either button or GPIO pulled low).
The converter without the supervisor works flawlessly. As soon as I connect the supervisor, even without any manual reset signal (MR) present, the converter stops.
The reset output is open drain, the enable input has an internal pullup as well as the manual reset input.
I tried using different values for the reset time, this did not change anything.
Thank you very much for your help in advance, I think I am missing something very stupid.
All the best pitchbent
