Just curious, did you model the circuit using software or solve it by hand? Did you build the circuit on a breadboard? You should validate your design in some way before you open EAGLE.
do I have to tell JLCPCB which rcl components they should put
In short yes.
You will need to give them a bill of materials (BOM). The BOM will have part designations for each component (e.g. R1, R2, C1, C2, etc.) that correspond to actual parts that will match the designations on your PCB footprints. Let's say you want R1 and R2 to both be 10kOhm resistors but you want R1 to be a 1/4 watt 1% tolerance 10kOhm resistor and you want R2 to be a 3 watt 5% tolerance 10kOhm resistor then you will need to have a two lines on your BOM; one for R1 and one for R2. Something like this:
Component Identifier Part Number
Resistor R1 R25w1p10
Resistor R2 R03w5p10
Then they will know to put the R25w1p10 resistor on your PCB where you have the footprint for R1 and the R03w5p10 resistor on your PCB where you have the footprint for R2. If you want R1 and R2 to be the same then you could do this:
Resistor R1, R2 R25w1p10
Let's say you put a 0805 resistor footprint on your PCB design and you want a 10kOhm resistor to be placed there. Now it seems you are asking if you can leave the part number section of the BOM blank. Well if you look at digikey there are 192 10kOhm resistors in stock in a 0805 surface mount package. Which one should they pick for you? They range in price from $0.10 to $18.77, in power from 0.1W to 1W, and in tolerance from 0.01% to 10%. How can they just pick one for you? you have to determine what requirements you have for each component. This will narrow down the 192 options to something much more manageable. Then you can select each part for your design. This will take some time but it's not too difficult. It will also teach you a lot about what is out there which will help you with future designs.
- I've never used JLCPCB but as Andy said they may have common parts in stock that you can have them put on your PCB. Even so, you will still need to tell them the specific parts to use from their selection.
