I have ordered some of these small joystick buttons and I'm not sure if they will be properly fixed just with the 6 soldering points, as you do some latteral pressure to action them.
If I create a custom footprint in Kicad I could consider these two plastic knobs below, or remove them, and do something with the metallic wings. I'm not sure what would be better or possible.
Any ideas or recommendations?
I have ordered also these ones, through hole:
I can try with both, are very cheap anyway, but I'm not sure how should it be properly designed in Kicad. I have all the measures from the aliexpress vendor. Thank you!
