I am building a PCB that has a voltage converter at some point. The step down module is configurable if i change one resistor only. The thing is that I want two different voltage outputs that would be configurable by the user.
For example, the voltage converter will "use" one resistor, but if the user changes the selection via a switch, then the previous resistor is "cut-off" from the circuit and the circuit "sees" the other resistor.
You can think of this as a custom potentiometer. I cannot use an existing potentiometer, since I want the values to be specific.
