I've designed a 4-layer board and when I run DRC I get this error claiming that the connecting between a via and the GND-plane is missing. Note that the bottom left via is the highlighted one that the error refers to.
Looking at the layout it seems quite obvious that the error is wrong since the next via and the component GND pads (which are obviously in the same zone on the top layer) do not trigger an error. There is also a solid ground plane underneath both these vias which extends throughout the board.
Furthermore, as you can see this is the only error I'm getting, but if I delete the troublesome via and run DRC again I get the same error, but for another via. And so it continues. Note also that there is no red DRC-error-arrow pointing at the via. Unclear why.
Any ideas on what to look at to find the source of this? The zones are refilled. I am using KiCad 6.0.4.
As per request, here are also some menus and extras. And before someone suggests it, no I don't think it's the island option casing this, consider the 2nd layer solid ground plane!
I can't share too much of the design so I don't want to snippet the whole card etc.
e
)? Also, could you show the whole board and layers (or, at least, a larger portion with some more connections visible)? \$\endgroup\$
