People advise not to change trace widths on a PCB because of the change in impedance of the trace and possible signal reflections for example. Does that still hold true when the trace reaches a component pad/pin (surface mount or through hole)? Or can I go from a 25 mil trace to a 50 mil trace without fear when the trace reaches the component pad (as if it were an "independent" trace)?
For example, if I have a power trace which, because of spatial constraint had to be small, can I make it bigger if space is available after reaching a certain component so that it may go to other components?
