I'm trying to learn how to use the 'include thing properly. I had this basic code that works fine to run some 7 segment displays.
module TopLevel(
input [9:0] SW,
output [9:0] LEDR,
output [6:0] HEX0,
output [6:0] HEX1,
output [6:0] HEX2
assign LEDR[9:0] = SW[9:0];
function [6:0] HEXER;
input [3:0] IN;
reg A;
reg B;
reg C;
reg D;
begin
A=IN[3];
B=IN[2];
C=IN[1];
D=IN[0];
HEXER[0]=!(A&&!B&&!C||!A&&B&&D||A&&!D||!A&&C||B&&C||!B&&!D);
HEXER[1]=!(!A&&!C&&!D||!A&&C&&D||A&&!C&&D||!B&&!C||!B&&!D);
HEXER[2]=!(!A&&!C||!A&&D||!C&&D||!A&&B||A&&!B);
HEXER[3]=!(!A&&!B&&!D||!B&&C&&D||B&&!C&&D||B&&C&&!D||A&&!C);
HEXER[4]=!(!B&&!D||C&&!D||A&&C||A&&B);
HEXER[5]=!(!A&&B&&!C||!C&&!D||B&&!D||A&&!B||A&&C);
HEXER[6]=!(!A&&B&&!C||!B&&C||C&&!D||A&&!B||A&&D);
end
endfunction
assign HEX0 = HEXER(SW[3:0]);
assign HEX1 = HEXER(SW[7:4]);
assign HEX2 = HEXER(SW[9:8]);
endmodule
And I was under the impression that `include "filename.v" would just effectively stick that file's contents into the code as if it was written there.
However the code
module TopLevel(
input [9:0] SW,
output [9:0] LEDR,
output [6:0] HEX0,
output [6:0] HEX1,
output [6:0] HEX2
`include "HEXER.sv"
endmodule
With Hexer.sv being
input [3:0] IN;
reg A;
reg B;
reg C;
reg D;
begin
A=IN[3];
B=IN[2];
C=IN[1];
D=IN[0];
end
endfunction
refused to compile properly. first it refused to compile when it was just Hexer.v claiming that "declaring global variables was a system verilog feature", and when I made it sv instead of just v it claims. "Can't resolve instance of object "HEXER""
So obviously `include is NOT just copy pasting the code over. What is actually wrong here?
I'm using Quartus, and its just a one button that says "Start Compilation", so I'm not sure what else to add. Whatever the Quartus default is I suppose.
